Moldy smell from a/c vents
1 Post
2012 GLK 350
We live in South Florida and it is humid here. I have noticed a moldy smell coming from the a/c vents when you first start the car. Is there any way to spray some Lysol into the intake to clean this up, or should we take the car to the dealer?
Metro Card : (
well, before everyone says search the forum, you should take to the dealer. they have a process to rid the a/c of the smell.
it's a pretty common issue for us w203 owners - now go search the forum
You can try to kill the mold in the evaporator, but even bleach cannot kill mold on a porous surface. These products are effective for mild cases:
http://www.bgfox.com/products.html?c...nce%20Services
One thing you have to do is make sure that your evaporator drain tubes are clear. Insects like to dam them up, and enjoy the flowing stream. I run a brush with a long wire handle up the tube from the bottom of the car. Compressed air also works.
If you can rent an ozone generator, put it in the car and run the blower running in recirculate for about an hour. Just be sure to let the car air out for a few hours after you remove the ozone machine.
Now, if your car is under warranty, complain until they replace the evaporator. That is the most effective way to remove mold.
2013 c300 4matic, 2002 c240
C55 ///AMG, 535xi
i hate that mildew smell, a tecnique I use... take out the air filter, spray lysol into the air vents with the heat blasting on high.... have the heat run for abt 5 mins then switch it COLD COLD COLD for abt 5 mins, then spray again, then switch to ur normal temp, this should keep u good for abt 3 weeks or so...
if you have a chance to, use a air hose and spray the AC hose under the car
They sell a special spray to do this but I guess Lysol would work. To prevent the a/c from getting mildew, when you use the A/C, run the cold out of it by switching off the compressor. I try to do this as I turn on my block, that way the A/C vents have a chance to warm up and reduce the chance of moisture building up inside them.
05' C230 Kompressor SS Mars Red 6speed--1990 300D 5speed
1 Post
2012 GLK 350
Mold is gone for now.
We took the car to Mercedes Benz of Ft. Lauderdale for its annual service. The other dealer where we purchased the car is farther away and had no available service dates for 3 weeks. This was ridiculous. The dealer put something in the system and it does not seem moldy now. We will try turning off compressor before shutting off the car. I think it caught mold by rotting on the dealer's lot in 2004 before we bought it in December.
05 C230wz 6M
The air coming out of my vents sometimes smells like urine...and when my car sits for a few hours on a damp day, it smells like trash when I first get in...oh, how i long for mere mustiness.
The dealer in Cherry Hill, NJ is so horrendous in every aspect that I just deal with it. Needless to say, whatever pleasant smell existed from the few strips of leather is completely gone.
'04 C230K
Performed Ultrasonic Cleaning Procedure
Had the same problem at 45,000 miles-
Check out P-83_30-74A FEB 05 A/C - Musty/Moldy Odors
Musty Odor is one of the first threads.
I brought my car to the dealer at a B service and complained of the musty odor they "Performed Ultrasonic Cleaning Procedure" maybe you should try that before you switch from musty to medical odor
D
D
05 C230K SS
D
D
2005 C230K SS Desert Silver
The odor will most likely return, as it did on my car.
Wurth A/C & Heating System Treatment works well. I use it on a monthly basis. You can spray it directly into the fresh air intake and into the recirculation intake.
Here's where to buy the Wurth treatment:
http://www.autogeek.net/wuachesytr.html
